My freezer is GE model CA13SMCRWH and the manual is for models CA10, CA13, CA16, CA19, CA21.
Last time I went into the freezer, the door didn't close tightly. That is, it is supposed to be snug but it was very loose. Nothing was pushing against the door.
I saw the problem is because there is a plastic hook, about 2-3" long that comes out of the door and into the freezer And evidently, normally works automatically to hold the door snugly closed. I never saw the hook before but perhaps because I wasn't looking for it.
To get the door closed tight, I had to push it and it seemed to latch (catch). I can open it again, also. This is alright, IF it stays working like this. My concern is that if the hook should fall out or fail to close or open properly, then I will lose all the food that's in there.
I understand that ideally I would have it serviced but I cannot afford that. Should I keep using the freezer as is or should I try to use the food as fast as I can in case it fails?
Another option is if I could repair it myself. And I am good with repairs but only if I know how to do it.
Thank you very much in advance if you are able to help me.
