Adjustable temp knob needed for oven
  • GE51
    • Sep 2008
    I can't seem to find the adjustable type knob for the oven temp. I want to calibrate it per your instructions, but can't find a replacement knob with the adjustments (on the web). Do you have any recommendations?
    Make? Model number??
    If your oven was designed to have its temperature control calibrated that way, it would have such a knob on it already. Otherwise the control itself gets the adjustment... if possible at all.
    LINK > How do I adjust the oven temperature on my range?
    BTW. An oven thermostat knob's calibration markings (OFF, 250°, 350°, CLEAN, etc.) and their direction on the dial (right higher, left lower, etc.) are specific to the control it is used on. Thermostats are not 'all the same', you can't mount just any thermostat knob.
    JFYI
