The seal in the spray arm broke and need to be replaced. The model number is DU810SWKU0. The part number for the seal is 3369045, number 12 in parts list. Do you have to disassemble the spray arm (screw #15) or can you install the seal in the pump outlet nut (part # 10) with out disassembling?
