Kenmore Dryer help
  • Myrkos
    Kenmore Dryer help
    I am having some trouble with my Kenmore Elite Dryer. Its a gas dryer model# 7005 with touch panel controls. When I start the dryer after setting my timer and temp it wont keep the settings it reverts to high heat and the timer sets itself to 40 min. I am unable to turn the dryer off or change any of the settings after it starts. It also beeps 3 short beeps and a pause continualy. The dryer runs like this beeping until I unplug the dryer or the 40 min. run out. If anyone has any experence with this and knows what I might do to fix this please help.
  • FreeApplianceRepair
    • Feb 2004
    • 69
    There should be a sheet of paper inside the control panel.
    It may help you out some more.
    I think the three beeps is some kind of error code. The sheet will tell you.
    It maybe a problem with a thermostat/thermofuse or the touch panel.
    John@FreeApplianceRepair.com
    www.FreeApplianceRepair.com
    • Rosie
      • Feb 2004
      Hi! I am having the same problem with my Kemmore Elite Dryer. Did you ever figure out what was wrong with it???
