Model # KSSP42QKS has a "call service" sensor light on in the refrigerator compartment. I noticed that the filter life was at zero and changed it. I shut down the unit to reset but the light came on again. Any suggestions on what it might be.
KitchenAid side by side refrigerator
Whirlpool fridge "call service"
It came back on immediately? I wouldn't think it has anything to do with the filter anyway.I shut down the unit to reset but the light came on again.
To determine what might be the cause of the display indicator the refrigerator's control would have to be put through its diagnostics. How to do that should be listed in the 'tech sheet' which should accompany the unit's wiring diagram.
Is everything working correctly otherwise, all temperatures Ok?
It's not running excessively long?
How recently has its condenser been thoroughly cleaned?
I wouldn't put off getting it looked into as more serious problems could develop depending on the present cause of the service indicator.
