Maytag Quiet Series 100 is Making a Grinding Noise
  • KrisCat
    • Mar 2009
    Model #: MDBTT59AWW
    Series#: 20933849CT
    A few years ago, my dishwasher started making a grinding noise and the repair guy found pieces of a pistachio nut shell that I must have left on a plate. The repair guy removed a number of parts from the bottom of the dishwasher to get to the shell bits.
    For about a year after, the noise was still there but maybe every 6th time I ran the dishwasher. Now for the last few months it's making the grinding sound everytime I run it.
    Is it safe to assume that the grinding sound is because something else is caught in the dishwasher? Can this problem burn out the motor? The cycles complete but I sometimes find detergent residue on the dishes in the lower rack.
    I would like to fix this myself, any suggestions are definitely appreciated!
  • Dan O.
    • Sep 2003
    • 2167
    Actual inspection needed
    No, there could also be a problem with the pump's components but just foreign material in it may be a possibility.
    Than I would suggest it may not be washing properly either... for whatever reason.
    Someone is going to actually have to open it up to have a look to try to determine the cause of the sounds. There is a service manual available for your dishwasher model if unfamiliar working on them.
    LINK > Maytag 'Tall Tub' Dishwasher Service Manual
    JFYI
    • KrisCat
      • Mar 2009
      Do you think it would be easy for a novice to open it up and look around?
      BTW - thanks for the link to the manual!
      • Dan O.
        • Sep 2003
        • 2167
        I'm afraid I have no idea of the abilities of the person involved. Some people could do more harm than good, others might be able to accomplish quite a lot.
        You can see exploded view diagrams of your model at the following link. Maybe they'll help you decide if you want to try?
        LINK > Maytag MDBTT59AWW Exploded Parts Views
        JFYI
