hello; i purchased a used gas cooktop and want to convert it to propane ....this is a STERLING cooktop....manufactured by NEW WORLD DOMESTIC APPLIANCE(they were no help)....serial-DOA299....label part-0522-11-900...tried to get a kit from manufacturer but they were no help....need a universal kit or something....maybe a step by step....please help
convert cooktop from gas to propane
Not in the USA??
Sorry but I've never heard of STERLING nor of NEW WORLD DOMESTIC APPLIANCE and I have no idea what is required on your model to convert it. Did you check the owner's manual or installation instructions?
As HayZee518said, there is no such thing. If the burner orifices need to be changed for LP operation, you need to get the correct ones for the specific model. If it was designed with universal (ie. natural/LP) orifices, there should be instructions for conversion in the appliance's documentation. See if you can get ahold of it.want to convert it to propane ....need a universal kit
Dan O.Comment
Channel: Appliances
