We have a KitchenAid frige model KSCS25FTMS02. We noticed lately that the water is not cold. Its coming out at 72F and the specs says it should be around 50F. The frige makes ice and the freezer section is cold. What could be causing this? Is there a chilled water reservoir at the back? If there is, what could cause it to be not cold?
water not cold from water dispenser
Channel: Appliances
