The freezer is staying cold but not freezing. At the coldest temperature it seems that it is staying cold enough to keep meat and such from going bad, but in no means freezes the stuff inside. The meat is always malleable and any sort of ice cream you put in always ends up liquid. When we put things in there completely frozen it ends up thawing out, not going bad, but not frozen like you would like your freezer to be. Any idea what could be the problem here?
GE SSS25SGPA SS side by side refrigerator - freezer staying cold but not freezing
Tags: None
You can check the compressor and also something simple as making sure the gasket is tight. Another thing, is the fan working? -
Is the compressor running continuously?The freezer is staying cold but not freezing.
Some possibilities for your symptom could include a defrost system problem, a refrigeration system problem or the evaporator fan not working. Those are discussed at the following link:
LINK > My frost free refrigerator is not cooling properly. What might be the problem?
JFYI
=D~~~~~~Comment
