Hello.
From time to time during the bake cycle there is a strong smell of gas coming from our Magic Chef gas oven. It seems to be coming from the rear vents of the oven, but on that point I could be mistaken.
I have recently replaced the bake ignitor, plus I have made sure that the burner tube is clean -- but still there is the gas smell. Again, this gas smell is not always present, rather we detect it only at various (random) times during the bake cycle.
The oven seems to heat up to the desired temperature without any gas smell, but then during the baking cycle we sometimes start to smell gas.
This gas smell only occurs when the oven is ON. The main gas line leading to the back of the oven was checked for leaks, and there were none. Also the oven itself was checked for leaks (pressure was applied to the gas inlet of the oven and there was no leakage detected in the oven itself.)
Our local repairman is scratching his head, thus I turn to you, my distinguished group of problem-solvers
Thank you in advance.
Steve Fox
Steve Fox
