Frigidaire
  • mash
    • Feb 2010
    Frigidaire
    Model FRS23BH6CSO
    Water leaking from water filter holder(bottom), occurs when using water dispenser on door or ice maker is low and has been running more to make ice. Have tried changing water filter, no help.
    Maybe the housing the filter plugs into is cracked or the tubing that attaches to that base is loose or also cracked?
    LINK > FRS23BH6CS0 Water Filter Base
    Actual investigation will likely be necessary to try to determine the actual cause in your case.
