Kenmore dishwasher won't stop
  • JIMBOBOLTH
    • Feb 2010
    Hello,
    I have a Kenmore 16514200 dishwasher. It seems like it goes in an endless loop of wash/clean cycle.
    Simple question - Any idea how long this should take?
    More complex question - If it is not my impatience, and is any actual problem, any ideas?
    Thanks
    Jim
    Recheck model number
    That model number is incorrect or incomplete. It is at least missing the 3-digit manufacturer's prefix. Please double check it. If you post the correct model number we can look it up to see what appliance design you're dealing with.
    LINK > Model Number Tag Search
    Some models may have a 'soil sensor' which adds extra wash/drain cycle(s) if it determines the wash water is still soiled (ie. indicating the dishes aren't clean). That could be caused by the machine not draining properly or a problem with that sensor.
    Also, most electronically controlled models monitor the water temperature and can extend a wash cycle to heat the water if it should get too cool during a wash... depending on the wash cycle selected. That could be due to too cool of wash water entering the machine during a fill. (Do you run a nearby tap until hot before starting the dishwasher?) Low water temperature might also be caused by a defective heating element, failed temperature sensor or defective electronic control (if used on whatever dishwasher model you have).
    Someone will likely need to determine if extra wash/drain cycle(s) are indeed being added or just the wash time is being extended in an attempt to heat the water according to the wash setting selected.
