My DW is making lots of noise and it appears to have some broken plastic parts. The wash impeller is broken at its stem, that I know to replace. Below that is a plastic part that could be part of the Motor Shaft Seal and Impeller Assembly. I am not sure about that., it looks broken and worn down but I am not sure what is it called.?
KitchenAid KDC-21 Dishwasher
The common repair parts needed for the pump on your model are:The wash impeller is broken. Below that is a plastic part that could be part of the Motor Shaft Seal and Impeller Assembly. I am not sure about that
LINK > Wash Impeller
and below it,
LINK > Drain Impeller and Seal Kit
Few other parts for the pump are ever needed.
Channel: Appliances
