Frigidaire Ice Maker not working
  • bja1016
    • Jan 2009
    • 22
    I have a Frigidaire side by side...model number: FRS6LF7JS3...Serial number: 4A93415199
    I have done the unplugging of the appliance and checked the water line that runs to freezer in the back of the unit. When I plug the fridge back in with the water line disconnected no water is being pumped thru the line. The line isnt frozen or plugged. My auger turns in the dispenser...but no water is making it into the tray. Any help would be highly appreciated
    Clarification needed
    What "water line" are you referring to???
    Will the icemaker harvest (dump) ice cubes if the ice mold is manually filled with water? That should at least tell if the icemaker is capable of functioning.
    BTW. Appliances do not "pump" water into them. A valve simply opens and allows the house water pressure to force water through. You can read how an appliance water fill valve operates at the following link:
    LINK > How do I test a water fill valve?
    JFYI
    • bja1016
      • Jan 2009
      • 22
      I got this issue fixed. Turned out the freezer setting was set to high and the line was freezing before it made ice.
        Too cold?
        I assume you mean the icemaker fill tube that goes through the cabinet.
        Too cold of temperatures will not usually cause that although the freezer shouldn't need to be set to colder than -5°F.
        The most common cause of the icemaker fill tube freezing closed is water continuing to trickle though it once a fill should have stopped. Those trickles freeze one by one until the aperture gets totally blocked off.
        If it freezes closed again, more investigation will likely be necessary.
