kenmore Free Standing Elite Ice Maker
  • bethieangel
    • Jun 2010
    My ice maker will not make ice or turn on. It does have power because when I turn on the cleaning cycle it will fire up. Any ideas??
    THanks so much for any help. It is only 5 years old and has had part of the compressor replaced.(it was under warrantly) and the heating grid that melts the ice replaced... THanks,
    Beth
    Model number?
    I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post it we can look it up to see what appliance design you're dealing with to maybe suggest possible causes.
    • yamahagirl
      • Sep 2010
      Kenmore Elite 6.89483998
      I have had my free standing Kenmore Elite icemaker for 4 years and it has been repaired 4 times, new pump, new compressor. Also, defect part was replaced (after it flooded my kitchen). Again it is not working. Seem to have problem, doesn't make ice at all, after I turn it to "off" because it is so full and I don't really need it running, so I'll shut off for a day. When I turn back on, it will not make ice. Called Sears and they had me unplug it, plug back in....still no ice. It is cold, but no water coming in.
      Model # in Title.
        Ice machine not filling
        That is not a proper model number, please double check it. I found a listing for a model 106.89483998
        For just not filling, a first step would usually be checking its water fill valve (see the following links).
        LINK > Kenmore 106.89483998 Water Fill Valve
        LINK > How do I test a water fill valve?
        JFYI
        • yamahagirl
          • Sep 2010
          model #
          D....you are right the # is a 106.
          Sorry bout that, was trying to stick my head in the darn ice maker to see it! Helps to put glasses on.
