I have a 4 year old side by side Whirlpool with the Ultraease water dispenser. The house was empty for 2 months with the thermostat set to 85 degrees and now there is what looks like black mold all around the flapper door that delivers the ice cubes. It has also dripped down on to the push lever and plastic tray below. At first I thought it was soda that had been sprayed all over but on closer inspection found it was not. I've cleaned up best I can on the lower portion but would like to take the thing apart. How do you remove the cover for the dispenser? I don't see any screws. Does it snap on and off? I don't want to crack the thing until I'm sure of how it mounts. Anybody else come across this problem?
Thanks in advance,
Phil Vourtsis
Thanks in advance,
Phil Vourtsis
