No power to control panel on GE Profile dryer
  • Work first golf later
    • Aug 2010
    Reference GE Profile dryer model number DPSB620EC4CC.
    After checking, and not knowing the correct in resistance value of 3 components on the exterior of the heating element housing, I re assembled and turned on the dryer while looking for the elements to heat up, which they did. I proceeded to completely re assemble and after doing so lost all power to the control panel and only the interior light remained operational, any suggestions.
    after [reassembly] lost all power to the control panel and only the interior light remained operational
    any suggestions.
    Recheck your work? Look for loose wires and/or trace the power supply route to the control to see where the stoppage may be.
      • Aug 2010
      Checked all connections after re-removing drum, reinstalled drum and again checked all connections, still no go.
        Than as I said, someone will need to trace the power supply to the control to see where the stoppage is. If power WAS getting to the control but the control was not working, it might be defective and need to be replaced.
