washer just stops agitating; Frigidaire Laundry Center; FELG390UW0
  • norton101
    • May 2022
    • 6
    'Soak' cycle (this time ... but failures happen on other selections too). It fills and begins agitating, runs about 10-15 minuets, and then just stops with a buzzer. Usually we just get buzzes at cycle done or an unbalance. If I wait awhile and press 'START | PAUSE', the lid unlocks. Press 'START | PAUSE' again, after closing the lid, and it begins to agitate and runs the full 35 minuets of agitation (in other words this was not a 'PAUSE' but a restart without an initial drain or fill. Drain and rinse seem good and strong. Ideas?
    Update. The 'Soak' total cycle just ended. It completed successfully. The ending was strange. There were to beeps and all the washer side status light went out.
    Thank you.
    Aside ... they sure don't make'um like they used to. This will never make 30 years like my old units.
  • dwinston20223
    • May 2024
    • 14
    looks like you are facing control board issue, caused by malfunctioning control board or triggering a safety mechanism that stops the cycle, inspect the control board and for any obvious signs of damage, if you have better and deep knowledge of electronic, try resetting the control board by unplugging the machine for few minutes and then power it up again, if still the problem persists, you may need to replace the control board
