Washing machine stops during spin cycle
  • Gardenboy
    • 334
    Hello everyone! What could cause a washing machine to intermittently stop during the spin cycle? The machine agitates and drains properly, but sometimes the spin cycle either doesn't start or stops mid-way. The lid lock appears to be working, and there are no error codes. Could this be a motor issue, control board malfunction, or is there something else to check?
  • TinyTool
    • 357
    Hi there! Based on what you've described, there are a few potential culprits to consider. Since the agitation and draining are working fine, but the spin cycle is problematic, it could indeed point to a motor issue. The spin cycle requires more power from the motor, so if it's starting to fail, that might explain the intermittent stopping. Another possibility is a faulty control board, which could be sending incorrect signals to the motor. However, given that there are no error codes, this might be less likely.
    It's also worth checking a few other things. Make sure the machine is level, as an unbalanced load can cause the spin cycle to stop. You might also want to inspect the drive belt for any signs of wear or damage. A loose or worn belt could slip during the high-speed spin. Lastly, although you mentioned the lid lock seems to be working, it might be worth double-checking. Sometimes the lid lock can engage enough to start the cycle but not maintain a solid connection throughout.
    If you're comfortable doing some troubleshooting, you could try listening to the machine when it's supposed to enter the spin cycle. Strange noises might give you more clues. If you're not sure how to proceed, it might be best to call in a professional appliance repair technician. They can diagnose the issue more accurately and safely. Let me know if you'd like me to elaborate on any of these points!​
    • Gardenboy
      • 334
      Thank you, TinyTool!
