Washing machine noise
  • Washing machine noise
    Hi all! My washing machine makes a slight noise while spinning. It sounds like the drum might be hitting something. What could be causing this, and how can I fix it?
    Hi! Have you checked if your machine is unbalanced? Sometimes, the noise can also occur due to an uneven load in the washer. Is this something that happens every time, or have you noticed it happening only occasionally?
      Hi machinist!
      I don’t think the issue is due to an uneven load, as the sound happens intermittently. However, the machine is on a slightly unbalanced surface. It doesn’t usually move, but I’m unsure if the spinning cycle could create enough force to make it wobble slightly. Could this be the cause of the noise?
        It’s possible that the slightly unbalanced surface is contributing to the noise. Even if the machine doesn’t usually move, the high-speed spinning cycle can sometimes cause it to wobble just enough to create a sound. I’d recommend checking if the legs of the washer are properly leveled and adjusting them if needed. Placing a non-slip mat under the machine might also help stabilize it during spins. Let us know if that solves the issue!
          Thanks! I don’t have enough space to move the machine from the unbalanced surface because the plumbing pipes attached to it are too short. Do you think anti-slip mats would be effective on an uneven surface? If not, what other options do I have?
          Also, is it safe to use the machine with this issue? I’m concerned I might be damaging the machine by continuing to use it.
            You're welcome!
            Anti-slip mats might help stabilize your washing machine slightly, but they are not designed to fully compensate for an uneven surface. Since the surface is unbalanced, the machine might still vibrate excessively or move during operation, even with the mat in place.
            Here are some alternative solutions:
            1. Adjustable Feet: Many washing machines come with adjustable feet. Check if yours has this feature, as leveling the machine might resolve the issue.
            2. Use Plywood or a Platform: Place a sturdy, level piece of plywood or a platform beneath the machine to create a flat surface.
            3. Relocate Plumbing Pipes: While it’s more involved, extending the plumbing pipes would give you flexibility to move the machine to a better location.
            Regarding safety, it’s not ideal to use the machine when it’s unbalanced. This could:
            • Cause excessive wear and tear on the drum and motor.
            • Lead to leaks if the constant movement affects the connections.
            • Potentially void the warranty if damage occurs.
            Until the issue is resolved, it’s best to minimize usage to avoid long-term damage.
              I can't relocate the plumbing pipes at the moment. Do you think adding a vibration pad under the plywood would be helpful, or is the plywood alone enough to stabilize the washing machine?
                Adding a vibration pad under the plywood can definitely help if the washing machine is still shaking or moving too much. While plywood alone can create a stable and level surface, it might not fully absorb the vibrations, especially if the machine is on a slightly uneven floor or is an older model prone to shaking.
                A vibration pad, made of rubber or foam, can help absorb some of the movement and reduce noise. It also provides a bit of grip, which can prevent the machine from sliding around. If you already have the plywood in place, placing a vibration pad between the plywood and the machine could be a simple and effective solution. It’s an inexpensive addition, so it’s worth trying if the plywood isn’t completely solving the issue.
                  Got it, thanks!
                    Hi Eliezer. Thank you so much for your response! That’s really helpful advice. Right now, the machine is on a platform, but the platform itself is on an uneven surface. I’m planning to fix the uneven surface issue first before calling in a professional. What do you suggest?
                    • #11
                      Did you find the solution? I've faced a similar issue with my washing machine making noise during the spin cycle. Of course, it can be an unbalanced load and worn suspension springs, but I'll also check that the drum isn’t hitting anything loose inside. Also planning to go through the Amana NFW7200TW manual to see if there are any specific troubleshooting steps or common issues listed for this model. Sometimes it’s something simple like shipping bolts, loose panels, or shock absorbers starting to wear out. I’ll update if I figure out what’s causing it. Curious to know what worked for you as well.
