Keurig K-Supreme slow brew fix?
  • Tomhanks
    • 193
    Hello everyone!
    What's the best way to fix a Keurig K-Supreme that brews slowly or isn't dispensing coffee properly? I’ve heard clogged needles can cause this, but what’s the best way to clean them and keep it from happening again? ​
  • machinist
    Moderator
    • 386
    Hi, Tomhanks!
    It might have a clogged needle or some mineral buildup slowing things down. The first thing to check is the entrance and exit needles, coffee grounds can get stuck in there and mess with the flow. Unplug the machine, open the lid, and use a paperclip or a needle-cleaning tool to gently clear out any gunk. Then, run a water-only brew cycle to flush it out. If that doesn’t do the trick, it might need descaling. Just fill the reservoir with a mix of white vinegar and water (or use Keurig’s descaling solution), let it sit for about 30 minutes, and then run a few rinse cycles with fresh water. To keep it running smoothly, try using filtered water and cleaning the needles regularly. Hope this helps!
    • Tomhanks
      • 193
      Thanks! Cleaning the needles sounds like a good first step. When it comes to descaling, does vinegar work just as well as the Keurig solution, or is there a specific advantage to using one over the other? Also, how often should descaling be done to keep the machine running smoothly?
      • machinist
        Moderator
        • 386
        Vinegar works well for descaling since it effectively breaks down mineral buildup, but it can leave a lingering smell or taste if not rinsed thoroughly. The Keurig descaling solution is formulated to be odorless and may be gentler on internal components. If you use vinegar, make sure to run multiple rinse cycles with fresh water to remove any residue.
        As for frequency, Keurig recommends descaling every 3 to 6 months, but if you use hard water, you might need to do it more often. Using filtered or bottled water can help reduce mineral buildup and extend the time between descalings. Keeping the needles clean regularly also helps prevent slow brewing issues.
        Hope this helps!
        • Tomhanks
          • 193
          Got it, thanks! Do you think descaling will make a big difference right away, or is it more of a slow, long-term fix?
          • machinist
            Moderator
            • 386
            Descaling can make a noticeable difference right away, especially if mineral buildup was significantly affecting water flow. If your Keurig has been brewing slowly due to scale buildup, you might see an improvement after just one descaling cycle. However, if the issue is severe, you may need to run a second cycle or let the solution sit longer to fully break down deposits.
            In the long term, regular descaling helps maintain consistent performance and prevents clogs from forming again. If you pair it with routine needle cleaning and filtered water use, your Keurig should stay in good shape for longer.
            • Tomhanks
              • 193
              Thank you, Machinist! Very helpful!
