Troubleshoot Receiver
  • muribe
    • Apr 2011
    I have a denon avr-588 receiver that is in protect mode every time i turn it on. Doesn anyone know the best way to troubleshoot electronic equipment. I am assuming that there is a short somewhere causing protect mode everytime it is turned on. I have never tested electronic equipment and was told that i could use a multimeter and possibly find the problem. Anything will help thanks.
    Ideally for electronic circuits an audio and frequency generator plus an oscilloscope is used for testing. a meter will test resistors and in some cases capacitors.
    • shorteddiode
      • Apr 2011
      Do some searching on componet testing, like transistors. You may find that the power amp transistors are bad, or maybe capacitors. You will need a mutimeter and alot of reading on testing componets
