Hi have this mixer i used alot, but when i lent it to a mate he put a power adapter in to it set to a higher voltage which i reckon may have blown something but dont kno wat. any replies much appreciated.
2 channel dj mixer
if you are sure it was a non-standard power supply your friend used it could have been the wrong polarity assuming its a d.c. adaptor. depending on how high the voltage was, the regulator if it has one, should have kept the voltage constant, if the voltage was very high its likely that it could have destroyed the regulator too. with a bit of luck it will be just a fuse.....
good luck
peterComment
