Home theater setup
  • Kidd6488
    • 110
    Home theater setup
    We recently added a large family room to our house, and made provisions for everything we could think of. In 7 places, we installed blue plastic boxes with 3/4" KO's and ran 3/4" ENT down into the crawlspace. And in one place, we installed to double boxes, each with 2 ENT's going down. We intented to eventually install a home theater setup, with the bulk of things sitting by those double boxes. One we'll use a P&S home theater speaker connection plate (5.1) and the other we'll use a 9-space modular plate for the other hookups. The plan is to have a bigscreen at one of the 4 places in the room where there's a box, and the speakers at the 4 corner boxes. But we have to connect the TV to the rest of the home theater setup. What type of cables can you run that would terminate into a modular-type plate?
    Thanks,
    ~Jonathon Reinhart
    ~Jonathon Reinhart
    Use standard shielded coax with a full copper braid, jacketed. Can also use this stuff for the audio. Solder directly into the connector.
    • Kidd6488
      • 110
      even if we end up running component video (red,green,blue), would we have to run one coax for each one, or do they make like a 3-conductor cable for that purpose? Its probly like a 25 foot run.
      ~Jonathon Reinhart
      ~Jonathon Reinhart
        Check into the Belden Company - they manufacture cables n such you might find a composite audio video cable for your purpose
        • Kidd6488
          • 110
          Will do. Thanks.
          ~Jonathon Reinhart
          ~Jonathon Reinhart
            Belden Cable and Carol cable make wire assemblies. They got a CAT-5E cable assembly for audio, video, cable and video in one neat jacket.
