NAD 3240 PE Integrated Amplifier
  • rdgallo
    • Nov 2004
    • 67
    I purchased one of these amplifiers new in 1993 and used it very little. Recently I noticed that the sound coming from the right speaker is only about half the sound coming from the left. Does anyone know what I can do to repair this amp or should I just throw it away and purchase another. I know that it is not the speaker nor the speaker wire. It is definitely the amp.
    Thanks in advance!
    check the push-pull final stage. the input to one stage is the output of the other, then your signal is taken off this transistor. If one transistor burns up then the output is one half or something compared to one half of a full wave rectifier.
    • Troy
      Moderator
      • Jul 2002
      • 576
      Is there anything you don't know, Hayzee?
      Try
      Try
        Much!
        • rdgallo
          • Nov 2004
          • 67
          Hayzee, how do I check the push pull you are talking about?
