We had some problems with reception from the small dish network to our house. We have three receivers. Two went out over a period of a few weeks. So, I checked some of the connections. I was surprised to get a small tingle between my leg and the aluminum ladder while checking the three wires at the dish itself! Is there that much voltage in those wires??
Small dish cable voltage...
Tags: None
Grounding...
Ground rod? There are two for the main house, but...for the lnb's? Should I install a special ground by that pole? It's in cement, so I would have no confidence it's conducting even when wet.Comment
Ground cable.
Ah, yes. I have seen those. So all I need do is tie that to some kind of ground rod? I presume any where along the line would work? As long as it grounds the braid?Comment
