Buildin a low cost replacement for a bathroom vanity in a mobile home.
  • 46hillbilly
    • Oct 2007
    I have a very flimsy cabinet in my Mobile Home. It will collapse if I ever sit on it! Ideas and plans to replace cheaply; limited income. Single sink. 48 inches long.
    Thanks in advance.
    • 8747
    if you have room between two walls where your sink is now, a couple of 1X3 stringers fastened to the sides of the wall will support a 3/4" plywood top. this you could face with formica or tile if you wish. Then just extend the sides down and cut a door opening in one piece of plywood and if you cut the opening accurately, use the cut out as a flush door. you can get special flush hinges at rockler dot com.
