Adding small cabinets outdoor.
  • Adding small cabinets outdoor.
    Hi all! I’m thinking of adding small cabinets to my terrace for extra storage, but I’m not sure which materials would be best for outdoor use. Can anyone recommend weather-resistant materials or cabinets that can handle rain, sun, and temperature changes?
    Hi Gardenboy!
    One of the best materials you could go with is marine-grade HDPE plastic - it's basically bombproof against weather and won't give you any headaches with maintenance. It's not the prettiest option out there, but it'll definitely get the job done without breaking the bank.
    If you're looking for something with a bit more character, teak or cedar wood cabinets are gorgeous choices. They naturally resist weather damage and actually develop this beautiful silvery patina over time. Just keep in mind you'll need to give them some TLC once a year with a fresh coat of sealant. They're pricier, but many people think the natural look is worth it.
    For a modern look, powder-coated aluminum is a solid middle-ground option. It won't rust, it's pretty lightweight, and it comes in lots of colors. If you really want to go all out, marine-grade stainless steel is practically indestructible, though it can get pretty toasty in direct sunlight and might make your wallet cry a little! Whatever you choose, just make sure the cabinet has good ventilation and sits up off the ground a bit to avoid water pooling underneath. What kind of style were you thinking of for your terrace?
      Thanks for answering! I'm aiming for a modern look on my terrace. Do you think HDPE plastic could work with that style?
        While HDPE plastic is incredibly durable and weather-resistant, you're right that the utilitarian look may not quite fit the vibe you're going for.
        For a more contemporary, stylish look, I'd actually recommend taking a closer look at the powder-coated aluminum cabinets. The powder coating process allows for a wide range of sleek, matte color finishes that could complement a modern terrace design nicely. The aluminum construction also has a nice clean, minimal look to it. You could even find powder-coated aluminum cabinets designed with a bit more visual interest, like subtle textured patterns or angular lines, to really elevate the modern look.
        The only potential downside is that the finish may show some wear over extended outdoor exposure, but regular cleaning and the occasional touch-up should keep them looking sharp.
          How soon after installation would I need to start maintaining the powder-coated aluminum cabinets?
            I'd recommend starting the maintenance routine within 1-2 months after installation. The initial outdoor exposure can cause some minor dulling or blemishing of the finish, so regular cleaning and any needed touch-ups are important during that first season.
            Specifically:
            • Clean the cabinets every 2-3 months using a mild soap and water solution. This will prevent dirt and pollen buildup.
            • Inspect for any small chips or scratches that may require touchup paint every 6-12 months.
            • Be extra diligent about cleaning after severe weather events like heavy rain or snowfall.
