Replacing several receptacles in my new used home. Some difficulties however....
The priors decided to spray the expanding foam insulation directly into the outlet, where the wiring is housed. This 'glued' everything together in place and has made it quite difficult to remove the old outlets.
However it is doable, just a pain. My question is this...
Several of te outlet boxed seem "loose" behind the drywall. One is especially and it seems impossible to plug anything in because when I push, the outlet just sinks into the wall. I cant even attach a cover plate, as the outlet is so recessed. What do?
