Bosch 33614 cordless
  • TOOLFIX
    • Mar 2011
    Cordless Bosch 33614 won't start by itself. Spinning the 'fan' after removing the shield will start the drill and then it will run. If stopped for more than a couple of seconds, it will not start again without spinning it manually.
    bosch tools are unique in that hey have brushes that, when worn, lift the brush off the armature. there's a little plastic piece embedded within the brush with a spring. another reason is that the armature has an open somewhere within.
