I need to replace a very old wire running from a 50 amp breaker in my main service then up a wall and to the outdoors 14 ft above ground, then in the air about 25 feet to a sub panel in an outbuilding. Total length of the wire from main to sub is about 50 feet. Can I use 6-3 UF wire rated for underground, or do I need some other type? The current wire is an extremely old 3 wire whose type I cannot see.
Thanks.
Thanks.
