Looking at the wiring diagram on the control box it shows:
Input 230V 1 Phase
Line input from 2 pole circuit breaker:
Green wire to GND
Black wire to L1
Black wire to L2(N)
Output to Motor:
T1 to blue wire on motor
T2 to red wire on motor
T3 to black wire on motor
GND to green wire on motor
I am using a 4 wire 20 amp double pole 20 amp breaker which it calls for.
The wire I ran over to the pump is 4 wire #10. (Black, Red, White, Bare)
Do I just use the the black, red and bare ground and ignore the white or do I join the white and bare ground to make the GND.
Or should I go ahead and use the white for the gnd and if so where do I hook the bare ground.
I know in the old days you did not have the bare ground or what I call the mechanical ground.
Any help appreciated.
JRH
Input 230V 1 Phase
Green wire to GND
Black wire to L1
Black wire to L2(N)
Output to Motor:
JRH
