Outlet with no ground
  • Anton
    • Mar 2004
    How do I ground two existing outlets that are six feet apart in a finished basement? They are mounted on the exterior of the walls with one white, one black, and one copper in each of the outlet boxes. The ground (copper) is connected to the screw in the box but isn't active according to the circuit tester.
  • irregularjoe
    • Nov 2003
    • 176
    Trace back the circuit to the panel and connect the ground there.
    If that's not possible, ground them to a nearby metal cold water pipe, or drive a grounding rod into the earth and ground them to it with a pipe clamp.
    • Anton
      • Mar 2004
      anton heard
      • Anton
        • Mar 2004
        Great! There is a cold water pipe 3 feet away from the outlet. I'll try it and retest.
        anton heard
        • Jimmer
          • Oct 2003
          • 274
          Anton,
          Connecting to a water pipe works great as long as it is not interrupted by a plastic sleeve, water softner or other unit that is non-conductive. If you have something like this on your water supply then you can clamp a cable to the pipe on either side of the interruption and that will maintain the good ground.
          Good luck, Jim
          • irregularjoe
            • Nov 2003
            • 176
            "ground them to a nearby metal cold water pipe"
            the operative word being metal.
            quote:Originally posted by Jimmer
            Anton,
            Good luck, Jim
