pump
if you were to take apart the pump, replace the oil with moisture free oil, like the mineral oil used in air conditioners. any kind will do as long as there's no water vapor in it. its function beside lubrication is to draw off heat and pass it to the surrounding effluent water. when you get the housing off you'll see how the wires are connected inside the motor winding.
