Through the Wall connection for outside generator to power in the house.
  • vdotmatrix
    • Feb 2004
    • 314
    During the last power outage I set a generator out side and powered a few items for 20 hrs. until power was restored.
    Trouble was I had to have the window open enough to pass the power cord into the house, making this area unsecure.
    I want to have an outlet I can plug the generator output in to from the outside, and then plug in from the inside for power.
    I can't find what I might need for this project.
    PROJECT: Drill a 1" hole through the wall for an electrical conduit and have outlets on both sides .
    Any ideas?
    thanks
    generator connection
    Most people in an emergency situation use a generator to power a few items.
    I agree on your security concern but there is stuff out there you can use.
    To remain safe and without electro shock issues, the receptacle outside and inside needs to be contained.
    Try this. Use a 2X4 weatherproof box. Remove the back knockout, install a 1/2 inch EMT connector, a piece of 1/2 inch emt, another connector and a surface mounted wiremold box.
    Get hold of something called a MALE TWIST LOCK MOTOR BASE RECEPTACLE that will fit the 2X4 box.
    Get the matching female connector body for the motor base.
    Thread some solid wire through the emt, strip back some romex without the jacket [black, white and ground.
    Inside install a standard 120 volt duplex receptacle and plate. Outside install the motor base in the box. Add a weatherproof cover and yer all set!
    Use the plug, female connector body extension to go from your generator to the motor base.
    • vdotmatrix
      • Feb 2004
      • 314
      Yeah ... simpler than I thought....I have an idea now....the fixtures through the wall need to be rated 30amps ...Love it!!! thanks man...I was thinking this thing way too hard thinking there was something on the market for this application but I can just do this as if it were a commercial application using heavy duty components like you describe!!
      thanks again....big weather coming this way...
        receptacle
        that "thing" is called a flanged receptacle. Leviton makes one.
        LC_IMG_JPG_175_2615
        Color: LC IMG EZ COLOR WHITE.JPG White
        Additional Views
        UPC Code: 07847780661
        Country of Origin: United States
        *Eligible for ARRA funded projects
        NEMA:
        L5-30P
        *May include one or more globally sourced components.
        *Disclaimer
        Product Lists
        Add to Product List View Product List
        Quantity:
        Share on facebook Share on twitter
        More Sharing Services
        Locking Wiring Devices
        Where To Buy
        Find a Store
        Brand Features
        Leviton’s industry leading locking devices, such as our Black & White line of industrial grade plugs and connectors and our V-0-Max line of industrial grade flush receptacles, offer superior performance, long lasting reliability and other features that are backed by a lifetime warranty.
        Item Description
        30 Amp, 125 Volt, NEMA L5-30P, 2P, 3W, Flanged Inlet Locking Receptacle, Industrial Grade, Grounding - WHITE
        Related Products
        Discussions
        Support
        Technical Information
        Top
        AC Horsepower Ratings
        At Rated Voltage: 2 HP
        Electrical Specifications
        Grounding: Grounding
        Amperage: 30 Amp
        Voltage: 125 Volt
        NEMA: L5-30P
        Pole: 2
        Wire: 3
        Dielectric Voltage: Withstands 2000V per UL498
        Current Limiting: Full Rated Current
        Temperature Rise: Max 30C after 250 cycles OL at 200 percent rated current
        Environmental Specifications
        Flammability: Rated V-2 per UL94
        Operating Temperature: -40C to 60C
        Material Specifications
        Face Material: Nylon
        Body Material: Nylon
        Line Contacts: Solid Brass
        Terminal Screws: Brass 10-32
        Grounding Screw: Brass 8-32
        Strap Material: Thermoplastic Nylon
        Color: White
        Mechanical Specifications
        Terminal ID: Brass-Hot, Green-Ground, White-Neutral
        Terminal Accom.: 14-8 AWG
        Terminal ID: Brass-Hot, Green-Ground, Silver-Neutral
        Terminal Accom.: 18-10 AWG
        Product ID: Ratings and NEMA I.D. permanently marked on device
        Termination: Back
        Product Features
        NEMA: L5-30P
        Color: White
        Standards and Certifications
        NEMA: WD-6
        ANSI: C-73
        UL498: File E13393
        UL Fed Spec WC-596: File E13393
        CSA C22.2 No. 42: File LR-406
        NOM: 057
        Warranty: Lifetime Warranty
        Support
        Top
        Dimensional Drawing
        Wiring Diagram
        Discussions
        Top
        View All Discussions
        Related Products
        Top
        Previous Next
        2613
        30 Amp, 125 Volt, NEMA L5-30R, 2P, 3W, Locking Connector, Industrial Grade, Grounding - BLACK-WHITE
        2613-B
        2613-CY
        30 Amp, 125 Volt, NEMA L5-30R, 2P, 3W, Locking Connector, Industrial Grade, Grounding - YELLOW-WHITE
        WP2
        1-Gang Flush Mount 2.24 Inch Dia. Device Receptacle Wallplate, Weather-Resistant, Thermoplastic Glass-Fil... More
          HayZee, can you re post those Jpeg's please ? I can't see them .
            through the wall gang
            sorry about the last answer. when I cut n pasted I thought the image would show.
            full description is:
            30 amp twist lock, 125.250 volt. L10-30P
            #2665
