My lights on the ceiling fan don't work. It has three bulbs. Not all three bulbs could be burnt out at once? I took the light off, it has two plug in connectors to the fan. The fan was wired such that the lights and fan come on when switched. I took the light assembly to a light store and they checked it and they jumped the wires and everything worked.
I checked the power feed from the fan unit with a tester the line is hot when the light is not plugged in, so I figured the connectors must be faulty. I cut them off and wired them together using wire nuts. Same result. I even tried just wiring one of the three light directly. Stumped. Any thoughts or ideas?
Thank you.
Thank you.
