there should be a bare ground wire in the romex cable. red and black go to the outside terminals, bare goes on the L shaped terminal and the white goes opposite this terminal.
The "L" shaped terminal of this receptacle is the NEUTRAL. The white connects to this, NOT the ground.
Older 3-wire dryer receptacles omitted the ground (the neutral served both purposes). If a ground is present connect it to the box (if metal) or just fold it back in the box (if plastic).
