Hi all, I was wondering if anyone could help me with this...
I replaced the 100w bulb in my bathroom with a 60w that only uses 15w. Turned it on and it sparked and then wouldn't work (new bulb was/is still fine). So then I tried replacing the bulb in the hallway in front of the bathroom, worked for about a couple minutes and then went out, no sparks.
I checked my breaker box, all breakers turned on, but turned them off and on (they're not labeled and I had no idea what each was for). The hallway then worked for a few seconds but went out again. The bathroom still would not come on at all.
What's going on? Loose wire? Is it easy to fix?
Thanks in advance!
Thanks in advance!
