Hello everyone, first post!
My question is:
I just had an electrician install a new 15 amp breaker to my panel up to a dedicated GFI receptacle. When I looked at the receptacle I noticed that it is 20 amps!
From everything I have read the amps of the GFI and the breaker should match. Is there a reason other than error that this was done? The 20 amp GFI must have been more expensive than a 15 amp so he obviously did not do it to cut costs...
Thanks for your help!
My question is:
The "guts" are the rated the same, but the plug shape is not; probably cheaper to manufacture this way.
