I would like to get some advice on wiring a 100 Amp subpanel for my Garage/Workshop. I recently completed my garage, after about 2 years of planning, negotiating contracts, contractors, inspectors and the like. Now the next step is wiring the Garage. After Calling about 6 different electrical contractors and actually getting one somewhat reasonable quote $2750.00 and one outrageous quote $10432.00. I have decided to try and do this myself. I have several friends who are electricians or have done a substantial amount of wiring and have done quite a bit of research myself. I am reasonably confident I can do this as I have done basic wiring for outlets and lights and met code and passed inspection, but never have installed a Main Panel or Subpanel. My problem is I am getting somewhat conflicting information on what type of wire to use. I am somewhat meticulous about how things are done and I also want this done to code and have as little problem as possible for inspection.
I need to run a feeder from my 200 Amp Main Entrance Panel to my 100 Amp Subpanel to be located in my garage/workshop on opposite ends of the house. The feeder must run 42ft across the crawlspace and then thru approximately 37ft of 1-1/2" schedule 40 conduit under the garage floor with about 5 additional feet on both ends to get to the panels. This gives me a total of about 90ft we might as well just say 100ft. Going thru the crawlspace is not as bad as it sounds since it is paved and well lighted. I have decided to use Copper even though it is much more expensive because the diameter is smaller for copper and I am bit concerned about the pull thru the conduit as it has two 45's and three 90's. Also, Aluminum has some drawbacks in regard to installation when anti oxidizer is improperly applied creating problems down the road. I just would like to avoid that and just spend the extra money for copper. With the amount I am saving doing this myself, I will still be way ahead. I am using a 100 Amp 24 circuit Square D QO Subpanel as that is what is used in my 200Amp Main Entrance Panel and I just as soon keep them the same brand. The 24 Circuit Panel is probably over kill as I will only be using about 8 circuits but my main panel is full, as I have electric baseboard heat, and I wanted extra circuits if I should ever need something else wired for the house or garage.
Now the problem, what wire to use? Through my research, and info from electricians and friends etc. I have about four possible scenarios for the feeder wire for this 100 amp Panel.
SCENARIO #1; Use SER 4-4-4-6 Copper across the 42ft Crawlspace and thru the approximate 37ft of schedule 40 conduit. Use a 90 Amp Circuit breaker in the 200 amp Panel to supply the feeder. Leave the 100 amp breaker in place on the 100 amp Panel.
SCENARIO #2; Use SER 3-3-3-5 Copper across the 42ft Crawlspace and thru the approximate 37ft of schedule 40 conduit. Use a 100 Amp Circuit breaker in the 200 amp Panel to supply the feeder. Leave the 100 amp breaker in place on the 100 amp Panel.
SCENARIO #3; Use SER 2-2-2-4 Copper across the 42ft Crawlspace and thru the approximate 37ft of schedule 40 conduit. Use a 100 Amp Circuit breaker in the 200 amp Panel to supply the feeder. Leave the 100 amp breaker in place on the 100 amp Panel.
SCENARIO #4; Use four Single THHN Wire's for the feed. I really want to avoid this as I believe I will need conduit across the entire crawlspace and the pull thru the 37ft of Conduit under the garage floor has me concerned already due to the number of 90's.
As far as the panel goes, my research tells me that I would not want a bonded neutral and ground since the workshop is attached to the house. I also should not need rebar in the ground for a grounded box since I am using 4 wires from the main 200 Amp panel which is already grounded. I believe Scenario #1 is for a light load type situation, Scenario #2 would be for heavier loads and Scenario #3 for a mega load situation like heavier machinery and such. I am thinking Scenario #2 would fit my situation since my shop would have a welder and air compressor on one hand but since I am the only one going to be in the shop, it would rarely have many things in use at once. Ok, I know this is a bit long winded but can anyone give me an idea weather I am on the right track here. Is any of these scenarios correct? Which, if any would you do in my situation? If none, How would you do it? Thanks in advance for any help anyone can offer.
