Hi Forum:
Over the past two months our electric bill has been through the roof. Last month was 3x, this month is 2x. I have two 1/2 possible suspects and I just wanted to bounce these ideas off you guys to see if anything seems like a prime suspect:
1. I have a fridge / freezer in the basement. I was using it as a fridge but changed the temp setting so that it's now a freezer. Could that be responsible? Sounds like a long shot but I'm not leaving any stone unturned,
2. My parents were visiting in September and after they left we noticed that the upstairs thermostat was turned all the way down, off the bottom of the dial. We think it might have been like that for a few days but I changed it back and switched off the cooling. I don't think that is the reason since I fixed that last month and we're still seeing a high bill (albeit not as high as last month).
3. When I was in the basement I heard the upstairs unit running (the furnace and fan are in the basement). This struck me as odd since the thermostat is OFF, not heat or cool. I checked the thermostat and noted that the fan was ON rather than AUTO. Could an HVAC fan running 24/7 cause our electricity bill to shoot up?
These are the only things I have found so far. I've switched off the basement freezer and switched the upstairs thermostat fan to off. My plan is to check the meter in a couple of days and see if I notice a difference. Right now we're averaging between 35 and 40 KWh / day so if either of these fixes are the real fix I think we should notice pretty quickly.
Thanks, Max
Thanks, Max
