how do yo separate a dual pole circuit breaker
  • vdotmatrix
    • Feb 2004
    • 314
    The transfer switch I am installing has a 30A breaker I want to separate but can't figure out how to do it.
    Any ideas
    thx
    is it a double pole circuit breaker? some double poles are connected internally inside the breaker - pole to pole. if there is a plastic or metal tie bar between the breaker handles, this tie bar can be removed. metal cut it out with a hacksaw. plastic should unsnap.
    • vdotmatrix
      • Feb 2004
      • 314
      Yes it is a double pole breaker with a metal bridge as pictured.....I am a knucklehead...until I removed this breaker did I see it was built this way.
      SO, I installed a Reliance 310C transfer switch which has in the A&B position a double pole breaker which I replaced with (2) 20a breakers to use.
      BUT, when I replace these breakers, the A circuit, which powers the Frig, will not energize. all the other circuits light up like a charm....
        if it is a single pole 20 it shouuld energize the bus. double check that you reset the breaker. sometimes they are difficuult to reset.
