power to receptacle, yet plug does not work
  • torps23
    • May 2004
    I have power to the receptacle, yet the plug does not work. I took a known working receptacle and same thing. My tester shows power from the black that is connected to the plug. Could there be a short from the neutral. I cannot figure it out.
  • Hawk
    • May 2004
    • 36
    Is the receptacle possibly a GFI that's tripped or on a line that has one. Or perhaps the neutral is on a switch? Just a thought and I apologize if I'm being presumptuous. (Looking for picture)
    <center></center>
    • torps23
      • May 2004
      It is a gfi, but have tested non gfi recep's with same result. I will check if any other connections are gfi. sometimes get a flicker of light in my tester. i am thinking it is a loose connection somewhere. new house and panel is not labeled.
      thanks
      <center></center>
      • Hawk
        • May 2004
        • 36
        It's not uncommon to have multiple hots, neutrals and grounds nutted together in a single recept box. Perhaps the loose connection might be there. [u]Shutting off and verifying the power of coarse</u>.
