3 way switch voltage ?
  • toby
    • May 2004
    I have followed the diagrams posted on this site for a 3 way. My question is when I am checking the wires at the light in on position my white to green is 0 A/C black to white is 120 a/c and black to green is 120 a/c.
    In off position white to green is 0 a/c black to white is 67 a/c and black to green is 67 a/c.
    Should I be concerned about the 67ac in the off position?
  • kactuskid
    • Mar 2004
    • 801
    I bet you're using a digital voltmeter. What you're reading are phantom voltages http://www.nema.org/engineering/papers/PhanBull88.html
    Try using an anolog meter and see what you read.
    • toby
      • May 2004
      [8D]After tracing everything back to the panel by jumping junction box to light and so on to check and see that I did not acidentally shave a wire through the wire casing I see how it is possible to have a phantom voltage problem.
      I was using a true rms digital meter and thankfully conclude that this was the problem.
      This forum is the best. Thanks for the valable information.
      • kactuskid
        • Mar 2004
        • 801
        No problem, one less thing to worry about [8D]
