Ceiling fan broke?! Help!!
  • Guest
    • May 2003
    • 6
    Hi!! How are you?? I think I broke the ceiling fan and I need help asap!! I was pulling the cords because I wanted to make it spin faster, and then it slowed down and stopped, and now it won't spin again. I've pulled the cords, and someone has played around with the circut breakers, but still nothing!! Please help!!
  • Todd
    • Oct 2002
    • 81
    Sounds like the motor burned out. Does it hum or have some vibration?It maybe that one of the wires is loose. The only other thing could be the cord but if you feel it clicking then thats not the problem. Take it apart and look at it but be sure to remember how you took it apart. Ceiling fans are easier to work on when they are hanging so do not take the whole thing down. If you need any more guidance, I'll keep checking back.
    T [8D]
    • Guest
      • May 2003
      • 6
      T [8D]
      Hi!! Thanks for your reply!! No, it does not make any sound or anything. It was working fine until I pulled on one of the cords on the fan and then it slowed down and stopped. Ok, thanks so much!
      • Guest
        • May 2003
        • 6
        Oh wait!! It does hum when I turn it on.
        • Todd
          • Oct 2002
          • 81
          If it hums, it probably is the motor.
          Ceiling fans are fairly cheap and usually have a year warranty. They are also fairly easy to install but have someone help you.
          T
          • Guest
            • May 2003
            • 6
            T
            Thanks for your reply again!! So there's nothing I can do except replace it?
            • Todd
              • Oct 2002
              • 81
              I would replace it. It is probably more expensive and a pain to just replace the motor. Someone else may have a better idea.
              T
              • Guest
                • May 2003
                • 6
                Ok thanks so much!!!
