blue plastic electrical boxes
  • vdotmatrix
    • Feb 2004
    • 314
    I used a blue box in the ceiling as a j-box for a splice my contractors left hidden, but i changed my mind at the last moment and turned it into a receptacle.....is this OK since I didn't ground the box but did ground the receptacle. I usually use a metal handy box for this but not thisa time?
    It's sometimes better to be lucky than smart.
  • volts
    • Mar 2004
    • 68
    vdotmatrix: Of course, all that needs to be grounded is the device. By blue box you mean plastic, hence the ground must tie directly to the outlet, as I presume you have done.
    • volts
      • Mar 2004
      • 68
      • Kidd6488
        • 110
        Yes, if I'm not mis-reading what you wrote, you used a blue plastic box for this junction-box-turned-outlet, right? Then of course all you had to do was ground the outlet. You can't possibly ground a plastic box!
        ~Jonathon Reinhart
        ~Jonathon Reinhart
