Breaker keeps tripping
  • Richard Montalto
    I recently replaced three 3-way dimmers, as well as the 3-way switches at the other end. Everything worked perfectly, and then the breaker began to trip continuously. The dimmers/switches are rated for 600 watts, and I'm well below that. any ideas or suggestions. Thanks.
  • Rewired
    • Feb 2004
    • 155
    Does it trip as soon as you reset the breaker or does it trip only when the switch or dimmer is flipped? Could be a pinched wire or something somewhere as well
    A.D
    • Xiotek
      It's a pinched wire. He's grounding out.
