what wire for what
  • HARRY
    • Aug 2004
    what wire for what
    ok, 14 gage is for lights, is 12 for the switches?
    Harry R. Plander
  • kactuskid
    • Mar 2004
    • 801
    They can both be used for wiring circuits, the wire gauge that's used is dependent on the circuit breaker that protects that wire. 14 gauge wire is protected by a 15 amp breaker, and 12 gauge wire is protected by a 20 amp breaker. It's ok to use 12 gauge wire on a 15 amp circuit but I don't advise it, You really want to maintain a consistancy of using the appropriate wire for the proper breaker and not mix the two, if done incorrectly it can lead to a fire hazzard. Here's a link that'll explain a bit more in detail for you.
    What you need to know about the different types of common cable and wire and how to select the right one for your home wiring projects.
    If this is a 15 amp breaker then stick with 14 gauge wire. It would also be a good idea if you bought your self a good book to learn about home wiring. The Black and Decker book on home wiring is a good one and will help tremedously in your projects. You can find one at Home Depot or any good book store.
      I used to wire houses with two gauges of cable 14 and 12. Now a days it doesn't offset the cost very much to use the same cable throughout - so 12 is the norm for everything. Ideally you could use 20 amp breakers on everything but that's up to you, no harm in putting a 12 ga line onto a 15 amp breaker. The cost of a 15 - 20 amp breaker is the same. Just mind you that circuits in a bedroom HAVE to be an "arc-fault" breaker under the new code rules.
