I’m stumped. The wife says last night at bed time, “The dryer’s not working. I have to put a load through 3 times for it to get dry.” Now that makes for a restful night’s sleep, hunh!
I checked the dryer with a load running. First time it felt warm, but not really hot. 10 minutes later it felt really hot, then after another 10 minutes it felt lukewarm again.
I have an older home with a fuse panel. I pulled out the fuse block with 2 x 30A fuses, and checked them with my meter. The one fuse initially showed 15 ohms resistance, then settled within 10 seconds to 0.2 ohms. The other fuse was a different story—the meter reading continued to fluctuate widely from 1 ohmn to infinity for as long as I watched it. It would seem to read between 0.2 and 30 ohms for awhile, then between 80 and infinity for awhile, then back to 0.2 – 30. Weird.
I put in a new fuse, and it seems to be heating up better.
I’m assuming the fuse failed, but I would have expected to see no continuity. Why would I be seeing fluctuating resistance readings?
PS. My meter is a Sperry DSA-700 Digisnap.
Mr Fixit eh!
Mr Fixit eh!
Mr Fixit eh!
Mr Fixit eh!
