baseboard heat voltage
  • Walt
    • Nov 2004
    Good Morning,
    Nice site you have here!
    I am planning on installing baseboard heat in one or two rooms of my house. We have heated with wood for 25 years and I need a little supplement in these rooms. In a year or so we plan to install a complete furnace/ac system but in the meantime...
    My question: What is the major difference, or pros & cons of installing 220 Voltage over 110 Voltage baseboard heaters???
    Thanks in advance!
    Walt
    No real difference - Watts is watts! Advantage of a higher voltage over a smaller voltage is the amps required to run the circuit. Basically it all comes down to the watts required for the heat. E.G a heater running 12 amps at 120 volts - at 240 volts requires 6 amps. Power = watts
    P=EI - P = power (watts) E = Voltage, I= Amps
    first example - P = 12 X 120 = 1440 watts - P = 240 X 6 = 1440 watts
    Same watts smaller current -
    • Walt
      • Nov 2004
      Thanks. I can see I need to do some studying! So I am assuming correctly that 240V heaters are no more economical to operate than 120V? And no safer??
      Thanks again!
        Efficiency goes up as the voltage goes up. The wire size goes down because of less amps required to run the equipment.
        30 amps @ 120 v
        15 amps @ 240 v
        7.5 amps @ 480
        3.75 Amps @ 600 v
        P=EI 30 X 120 = 3600 watts
        7.5 X 480 = 3600 watts
